1995 Saturn SC2 oil in the antifreeze
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
SONNIE711
I get oil mix in w/my antifreeze .I took it to a mechanic and he replaced the engine w/a 1998 engine ,replace the radiator ,water pump . and it still is happening the oil mixes in w/the antifreeze .antifreeze runs out fast need to add antifreeze constantly. what could it be
Feb 1, 2010 at 5:29 AM
SATURNTECH9
  • 30,869 POSTS
[quote:47a2ecc034="sonnie711"]Engine Performance problem
1995 Saturn SC2 4 cyl Two Wheel Drive Automatic 70,000 miles
I get oil mix in w/my antifreeze .I took it to a mechanic and he replaced the engine w/a 1998 engine ,replace the radiator ,water pump . and it still is happening the oil mixes in w/the antifreeze .antifreeze runs out fast need to add antifreeze constantly. what could it be[/quote:47a2ecc034]
ur still getting oil in the coolant after all that work?ur loosing coolant can u see it on the ground?or is it getting into ur engine block?let me know.
Feb 1, 2010 at 6:09 AM
TRUMAN861
  • 24 POSTS
Sonnie,
From experience I can tell you that you either have blown the head gasket or damaged the heads.
Sorry for the bad news
Jul 15, 2010 at 5:01 PM
