1995 Saturn SC2 not a common problem
1995 SATURN SC2
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
CHRISTYSC
I have just got my car put back in toe! Before this my car was pulling to the right when I put my brake on. When I took it to get looked at they said it has been hit underneath by maybe concrete. I have loaned my car to several different people so I have no ideal what has happened! But anyways, after putting it back in toe, it now pulls every which way with or without the brakes being touched! And my tire leans really bad when I turn! Leaning so bad that it is rubbing the transmisson casing!! The place I took it to said they had no ideal what could be wrong, but they checked the axles, tie rods and said they were fine! Any ideals, without seeing this problem? Thank you!!!
Oct 1, 2009 at 11:47 PM
SATURNTECH9
  • 30,869 POSTS
sounds like something is bent or the toe or camber is way off best i can suggest without seeing it.hope this helps.
louie
Oct 2, 2009 at 11:04 AM
