1995 Saturn SC2 Help
MICKI41
Transmission problem
1995 Saturn SC2 Two Wheel Drive Automatic
My car is having a pausing moment going in to reverse and doesn't want to kick into gear. I just checked my transmission fluid none is in there. Not sure why just had oil changed a month ago and all fluids were checked and topped off. No known leak. It was smoking a little bit when I checked the transmission fluid?
Does this mean transmission is shot or can i put more fluid in and might be ok, till i can get enough money to have it rebuilt
Jan 10, 2010 at 9:56 PM
SATURNTECH9
  • 30,868 POSTS
take a look under ur car see if u can see fluid leaking anywhere.i would top the fluid off to start with u check it idling in park on level ground hot.then see how ur transmission works then.let me know how it goes and how much fluid u have to add.
Jan 11, 2010 at 4:20 AM
