[quote:0abda88653="larry-mailman"]Transmission problem
1994 Saturn SC2 4 cyl Two Wheel Drive Automatic 114000 miles
when driving the car it will autamaticly down shift. will not go into 2nd gear. already change trans. and brain to car. What is you opion. how do you. run the dignostic code on this year of saturn also manualy[/quote:0abda88653]
heres how u get codes on ur car.on the drivers side bottom of the dash theres the obd1 connector where u would put a code reader on.look at the top row of it far right side theres two pins side by side.turn the key to the run postion dont start it and jump those two pins together and leave it that way.watch the service engine soon light flash.u will see it flash once then two faster flashes.thats a code 12 that means the computer is good it will do this 3 times if it repeats the code 12 after the 3 times u dont have any codes.but watch the light for example if u see 3 quick flashes then 2 quick ones that would be a code 32 it would repeat 3 times then go to the next code when it gets back to code 12 then the codes are done.let me know what codes if any u have and ill help u out with them.also a question for u what yr and model did u get the transmission and computer from let me know.
Apr 8, 2010 at 12:47 PM
