1994 Saturn SC2 Fan's not turning on?
MONICA P
Engine Cooling problem
1994 Saturn SC2 6 cyl Front Wheel Drive Automatic 200K miles
Got the raidiator replaced today. Mechanics can't get the fans to work. Is that a computer chip problem or a sensor problem? Will this be super duper expensive to get repaired?
Thanks!!!!
Aug 4, 2009 at 4:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
do fans turn on when A/C is switched on?
Aug 4, 2009 at 4:58 AM
MONICA P
A/C is broken...
Aug 4, 2009 at 5:09 AM
BLUELIGHTNIN6
  • 16,542 POSTS
ok, well you will need to supply 12 v power to the fan motor to ensure the motor itself is working. if the fan motor is working then it is just a faulty engine coolant temp. sensor needing replaced.
Aug 4, 2009 at 5:11 AM
MONICA P
OK, yep, that's what the mechanics said...is the car ok to drive home about 4 miles freeway?
Aug 4, 2009 at 5:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
yes, just keep an eye on the temp. gauge and do not allow engine to overheat.
Aug 6, 2009 at 1:51 PM
