1993 Saturn SC2 idle
147,000 MILES • 4 CYL • FWD • AUTOMATIC
SICWON
my car will start idle for about 30 sec. and die then wont start for about an hour
Apr 15, 2009 at 12:19 PM
  • 75,988 POSTS
Next time it dies out don't wait do below immediately
Get a helper
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, ECM,Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Apr 15, 2009 at 12:25 PM
