1991 Saturn SC2
300,000 MILES • 4 CYL • FWD • MANUAL
KELTIC2157
where is the cooling fan sensor
Sep 26, 2010 at 6:32 AM
SATURNTECH9
  • 30,869 POSTS
https://images.2carpros.com/forum/automotive_pictures/416332_1995_SL1_coolant_temp_sensor_2.jpg
There is two it's the bottom one with two wire's going to it the one you want to change.Also make sure you inspect the connector going to it if it's corroded then you will have to change the connector too.Make sure you get a brass tipped sensor the plastic tipped one's crack.
Sep 26, 2010 at 7:29 AM
