2002 Saturn SC1 fan motor not turning
111 MILES • 4 CYL • 2WD • MANUAL
JHAMILTON01
my fan motors not turning, while driving temp does not rise, while idle temp gets hoter and will over heat unless I start moving again, ac blows cool until temp rises, then blows warm, i replaced cooling system sensor, not the problem and the fuse is good. please help
Aug 6, 2009 at 12:30 PM
BLUELIGHTNIN6
  • 16,542 POSTS
do fans come on when A/C is switched on? if no, fan motor is bad. if yes, check cooling fan relay(s)
Aug 6, 2009 at 2:26 PM
