2001 Saturn SC1 Spray Leak
2001 SATURN SC1
125,000 MILES • 4 CYL • FWD • AUTOMATIC
ISUALUM
I have a spray of coolant coming from under the belt when the engine heats up. It's going through coolant fast. The upper hoses and overflow don't show any leaks, and I can't see the leak. The oil is fine, and the engine is running fine. I tried some stop leak, no effect. (Except turning the coolant brown.)
Feb 23, 2009 at 8:53 AM
DOCFIXIT
  • 18,828 POSTS
Me thinks you need a water pump
Feb 23, 2009 at 9:15 AM
