Raise up the front of the car put Jack stands under it. Remove the front wheels if ur just replacing the pads remove the bottom 14mm caliper pin and swing the caliper up out of the way compress the caliper with a pair of big pliers or a big c clamp then replace the pads. If ur going to take the rotors off and replace them or have them turned then u would take out the two 18mm bolts and the caliper housing and calpier will come off so u can get the rotors off. Let me know how it goes.
Louie
SPONSORED LINKS
Tuesday, October 27th, 2009 AT 10:38 PM
