2000 Saturn SC1 High engine idle
188,000 MILES • 4 CYL • 2WD • AUTOMATIC
7SSTREETSTOCK
I have been working on a saturn sc-1 for a friend of mine. He has had transmission issues in the past, and a few minor engine related problems. The primary problem we are fighting now is the engine will not idle below 1400 RPM. I have a code reader which is giving me a code for IAC engine RPM too high, and Bank 1 too rich.
I have replaced the IAC valve and cleaned the throttle body. I have even replaced the throttle position sensor and one of the o2 sensors. Yet I still have a high idle. I have hunted for vacuum leaks, and even checked the egr system for proper operation.
Someone please help me... this is my friends only ride and I need to get it running right ASAP!
Thanks
Feb 22, 2010 at 3:17 PM
SATURNTECH9
  • 30,869 POSTS
What are the code numbers u have in the computer?I would check the little s shaped hose that runs from the valve cover to the intake manifold they get holes in them and colasp.also I would check at the intake manifold gasket where the intake meets the head around the number 1 and 2 cyl which is if u go to the passenger side the first two cyl from left to right most of the time u can see the gasket wrinkled.if u let the car idle and spray carb around every where if the idle goes up or the engine stumbles or dies then u have a leak there.also u can check the coolant temp sensor it's screwed into the head below where the upper radiator hose goes onto the head.it has two wires going to it a yellow wire and a black wire.the sensors crack and leak coolant into the connector see if the connector is corroded if it is u will have to clean or replace the connector.make sure the car is cold when u check the sensor u will loose coolant.the sensor is under 20 if u replace the sensor make sure u get a brass tip one the plastic tip ones crack.see if urs is cracked a bad sensor will cause all kinds of problems high idle stalling no starts surging over heating etc.let me know what u find.
Feb 23, 2010 at 4:16 AM
