possible misfire-- jerky when engine is running, and loss of power from stop to start , tail pipe caked in black sut , change fouled spark plugs corrected for 10 days- check plugs no fouling, changed o2 sensor-- no change-- used fuel additive no change--- i figure next move is injectors, my dad says could be clogged catalytic converter. problem is i need my car and have $3 to waste on any one solution that does not fix the problem, the rest should go to the one solution that will get me rolling correctly again--- where to guys?
Oct 23, 2009 at 5:00 PM
