1997 Saturn SC1 Overheating
158,000 MILES • 4 CYL • FWD • AUTOMATIC
WIREMAN_86
I have a Saturn SC1 1.9 liter 4 cylinder and when you stop it will overheat if you do not have the air turned on. What is the problem?
Aug 14, 2009 at 2:57 AM
BLUELIGHTNIN6
  • 16,542 POSTS
could be many things. first to check is coolant level in radiator and overflow tank. if OK, you will need to remove thermostat and test it to ensure it is not sticking. also, are your cooling fan(s) coming on appropriately?
Aug 14, 2009 at 5:06 AM
