Trying to figure out what is causing my car to over heat while sitting in traffic or parked. I swapped out thermostat, swapped out coolant temp sensor, unplugged the battery, checked coolant level, checked fuse, checked relay by swapping with AC relay.
Cooling fan comes on when AC is on, but other wise it never comes on. It also shows that the car is over heating by the temperature gauge inside the car. Any ideas?
Oct 6, 2009 at 5:37 AM
