1997 Saturn SC1 OBD error codes and repair cost
1997 SATURN SC1
150,000 MILES • 4 CYL • FWD • AUTOMATIC
KMPIEFFER
  • 5 POSTS
I just bought a used car and it failed for emissions in the state of Massachusetts. The two codes were
P0341 and P0732. I looked up what the codes mean, but was curious if you could give ma alittle more detail and maybe an idea of repair costs? I am hoping to determine if I should fix it or return it to the seller if the costs exceed the purchase price. Thanks in advance for your advice.
Mar 26, 2010 at 2:28 AM
SATURNTECH9
  • 30,869 POSTS
The p0341 is usually like plugs and wires possible coils and sometimes the ignition module the price of repair would vary depending on what's causiing the code.if u want to do the work urself the plugs are like 10-12 the wires are like 30-40 coils like 40 ea u have two depending on how many are bad the ignition module is the most expensive part but they don't fail that often there usually over a 100.on ur p0732 that's second gear ratio incorrect that could be valve body there a couple hundred plus labor and dia that would be atleast 300-400 min for labor and dia could be more.could be a bad 2nd gear actuator there 40 plus a few hindered labor.could be a loose input shaft nut that would be 300-400 or could be a leaking 2nd gear pistion that would complete tear down of the trans or a used trans.so the p0341 isn't so bad but the p0732 could get real expensive.let me know.
Mar 26, 2010 at 6:04 AM
