i am showing code p732 and have no reverse except first time you use it after that no reverse the rest of the day,what do you think?
Nov 5, 2009 at 1:56 AM
SATURNTECH9
✓Experienced Mechanic
well the code u have is for second gear ratio and reverse uses second gear clutch pack so u could have a a bad second gear piston not holding pressure or loose input shaft nut theres a couple of things those are the first two that come to mind.u would have to have it checked out by someone that new what they were doing?hope this helps.
louie
Nov 17, 2009 at 2:21 AM
