1997 Saturn SC1 leaking
ROGG182
Transmission problem
1997 Saturn SC1 4 cyl Front Wheel Drive Automatic
My transmission is leaking somewhere near the filter. I have changed the filter when I thought that was the problem. There is sometimes a whinny noise like the tranny has low fluid until I get to higher gears or I been driving awhile. However that's also when it leaks the most. As long as the fluid doesn't get too low it operates normally.
May 31, 2010 at 6:31 PM
SATURNTECH9
  • 30,869 POSTS
[quote:ee0b4738ee="rogg182"]Transmission problem
My transmission is leaking somewhere near the filter. I have changed the filter when I thought that was the problem. There is sometimes a whinny noise like the tranny has low fluid until I get to higher gears or I been driving awhile. However that's also when it leaks the most. As long as the fluid doesn't get too low it operates normally.[/quote:ee0b4738ee]
So where's the fluid coming from?There's really no where for fluid to leak in that area except the filter,sensors,or the cooler lines.Is it a fast leak?Can you spray off fluid with brake cleaner and watch were it's leaking from?Let me know.
Jun 1, 2010 at 9:57 AM
