1997 Saturn SC1 Horn and Interior Light Issue on Saturn SC1
1997 SATURN SC1
128,000 MILES • 4 CYL • FWD • AUTOMATIC
TITAN318I
Hello, my girlfriend just purchased a 1997 SC1 which had a couple issues that may be linked. Right now I’ve noticed the following problems:
Horn does not work
Interior light turns on with Passenger door, but not Drivers
Interior/Dash lighting below Radio (Heat, AC, etc) does not light up.
All fuses look good, engine and passenger side, and it is a factory radio, so no odd installs. Searched the forum with no luck, hopefully someone has some advice, thanks!
Sep 23, 2010 at 5:29 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.It look's like we have a few different problem's actually.I would like to fix one issue at a time a lot less confusion for both of us.Do you have a multimeter?You will need one to trace the problem's down.
Sep 23, 2010 at 6:38 AM
TITAN318I
Unfortunately no multi-meter, but I do believe the dome light situation is just due to a stuck plunger. Main concern is why the heating/ac unit is not lighting up
Sep 23, 2010 at 6:56 AM
SATURNTECH9
  • 30,869 POSTS
If the door jamb switch is stuck you will need to replace it.You will need a multimeter to diagnose the heating/ac unit is not lighting up is it only that not lighting up?I have seen a bad ground cause that.Or it could be just a bulb but without a multimeter it's hard to tell.Your horn could just be a bad horn but again without the meter it's hard to say.
Sep 23, 2010 at 7:22 AM
TITAN318I
Thanks for your help, I'll look into using a Multi-Meter to narrow it down
Sep 23, 2010 at 7:36 AM
SATURNTECH9
  • 30,869 POSTS
When you get a multimeter let me know and we can go from there.
Sep 23, 2010 at 7:59 AM
