1997 Saturn SC1
220,000 MILES • 4 CYL • FWD • MANUAL
KILLER1
1997 SATURN SC1 1.9 L A/C PROBLEMS ALREADY REPLACED THE EXPANSION VALVE. A/C GETS DOWN TO 55 IN THE VENT. HIGH SIDE PRESURRE IS 270-280 PSI.. LOW SIDE PRESURRE IS 25-30 PSI AT 2000 RPM. HIGH SIDE PRESURRSE 220-240 PSI . LOW SIDE PRESURRE 50-60 PSI AT IDLE AIR TEMP AT IDLE IS 70 DEGREES. CAN YOU HELP ME FIGURE THIS OUT?
Jul 30, 2009 at 9:23 AM
DOCFIXIT
  • 18,828 POSTS
Did you replace drier and vacuumn down 2hrs.? If yes system is slightly overcharged. Fan on high at idle charge low is 33-35 high 190-210 vent temp 45-50 on Recirculation. System holds 24oz.
Jul 30, 2009 at 9:44 AM
