1997 SATURN SC1 1.9 L A/C PROBLEMS ALREADY REPLACED THE EXPANSION VALVE. A/C GETS DOWN TO 55 IN THE VENT. HIGH SIDE PRESURRE IS 270-280 PSI.. LOW SIDE PRESURRE IS 25-30 PSI AT 2000 RPM. HIGH SIDE PRESURRSE 220-240 PSI . LOW SIDE PRESURRE 50-60 PSI AT IDLE AIR TEMP AT IDLE IS 70 DEGREES. CAN YOU HELP ME FIGURE THIS OUT?
Jul 30, 2009 at 9:23 AM
