1996 Saturn SC1 smog
1996 SATURN SC1
14,100 MILES • 4 CYL • 2WD • AUTOMATIC
VEEISIN
MY CAR RUNS FINE HAD WATER PUMP REPLACED STILL CANT PASS SMOG ALSO CHANGE THE PLUG WIRES AND I ALSO CHANGED COOLANT SENSOR AND PLUGS WIRES JUST WONT PASS SMOG
Aug 20, 2010 at 9:09 AM
SATURNTECH9
  • 30,869 POSTS
I need a little more info like what your reading were?Also did it fail because the check engine light was on or because of too high of reading?The more detail's the better.Does your car burn a lot of oil?Did you replace your pcv?
Aug 20, 2010 at 9:56 AM
What's not passing with the tests-HC/CO/O2/CO2/NOX ???????
