1996 Saturn SC1 need assistance
1996 SATURN SC1
ARMYGUY050607
Engine Mechanical problem
1996 Saturn SC1 4 cyl Manual
my car will start but will not idle, once I hit the gas peddle it dies.... it slowely dies when it tries to idle, have changed the battery and spark plugs.
Apr 14, 2010 at 11:47 AM
OBXAUTOMEDIC
  • 3,711 POSTS
First is engine light on? If so would greatly help with diagnosis if you are able to get a scan tool to pull codes.
Here are a few possibilities....
Throttle Position Sensor
Idle Air Control Valve
Fuel Pump
Fuel Pressure Regulator
Vacuum Leak
Apr 14, 2010 at 12:09 PM
