1996 Saturn SC1 need assistance
ARMYGUY050607
  • 1996 SATURN SC1
Engine Mechanical problem
1996 Saturn SC1 4 cyl Manual
my car will start but will not idle, once I hit the gas peddle it dies. It slowely dies when it tries to idle, have changed the battery and spark plugs.
Wednesday, April 14th, 2010 AT 6:47 PM
OBXAUTOMEDIC
  • 3,711 POSTS
First is engine light on? If so would greatly help with diagnosis if you are able to get a scan tool to pull codes.
Here are a few possibilities.
Throttle Position Sensor
Idle Air Control Valve
Fuel Pump
Fuel Pressure Regulator
Vacuum Leak
Wednesday, April 14th, 2010 AT 7:09 PM
