1996 Saturn SC1 Coolant Temperture
1996 SATURN SC1
PIECES
Engine Cooling problem
1996 Saturn SC1 4 cyl Automatic 144544 miles
My car coolant light comes on to frequent. Do would I have some type of leak anywhere. I have filled the coolant tank with antifreeze, and i have tried water also. SO far water has worked the longest and the light have not come on in a couple a few days. Will this issue effect me passing the emissions test? And could you tell what i need to do to fix this problem
Nov 12, 2008 at 3:50 AM
DAVE H
  • 13,384 POSTS
does the car overheat ?? are you getting white smoke from exhaust ?? could be numerous reason's .. water leak/head gasket .. we need more info ?
Nov 12, 2008 at 7:12 AM
