1996 Saturn SC1 air conditioner
JAMESPETERS
Electrical problem
1996 Saturn SC1 4 cyl Front Wheel Drive Manual
my air conditioner is not working I'm getting power everywhere but it is still blowing out hot air, what can i check next?
May 1, 2010 at 8:52 AM
SATURNTECH9
  • 30,869 POSTS
Does ur a/c clutch kick in let me know.
May 1, 2010 at 2:12 PM
WINKEY2003
I was having the same problem the A/C clutch is not coming on. What could be the issue?
May 15, 2011 at 3:44 PM
SATURNTECH9
  • 30,869 POSTS
Bad A/C compressor/clutch too high or too low of system pressure low a/c charge.A lot if different things first thing to check is for power to the a/c clutch wire with the a/c on.Also is the radiator cooling fan come on when you turn the a/c on?
May 16, 2011 at 9:08 AM
