1995 Saturn SC1 left front wheel
119,500 MILES • 4 CYL • 2WD • AUTOMATIC
ANDYIII
left front wheel making nosie when you trun left sounds like a key being cut
Nov 12, 2009 at 8:25 AM
SATURNTECH9
  • 30,869 POSTS
Is it ur bearing or cv joint to find out if it's ur bearing and which one u can Jack up the front of ur car put it in on Jack stands with the front tires off the ground with the ebrake on put the car in neutral and spin the wheel with ur hand and put ur other hand on the coil spring of the strut and u can feel if the bearing is bad check both sides sometimes u could have two bad bearings better to make sure which one and if it's the bearing to begin with.so what was ur question anyways.
Louie
Nov 13, 2009 at 11:26 AM
