1995 Saturn SC1 gear shift linkage
1995 SATURN SC1
SUSAN DOWELL
Transmission problem
1995 Saturn SC1 4 cyl Front Wheel Drive Manual
I am unable to get 2nd, 4th, and reverse gears. I would like a picture of linkage connection for these gears because I'm not sure how it's not connected now.
Feb 21, 2010 at 6:07 AM
SATURNTECH9
  • 30,869 POSTS
Check under the hood make sure both the top and bottom cables are still attached the H shaped clips come off sometimes it's right on the transmission also look and make sure the cable ends are attached to the shifter tower as well.if nothing looks wrong there look under the shifter boot inside the car make sure booth cables are attached to the shifter.let me know what u find.
Feb 21, 2010 at 6:57 AM
SUSAN DOWELL
Thanks Louie - the bottom shifter connection has come off it's bracket and I don't know how it's supposed to be attached?
Feb 21, 2010 at 9:42 AM
SATURNTECH9
  • 30,869 POSTS
Are u talking about the connection that's at the bottom of the stick u shift with?or at the transmission under the hood let me know and I'll tell u how to fix it an how it's attached.
Feb 21, 2010 at 10:22 AM
SUSAN DOWELL
Thank you for your quick response - I am delayed in returning the answer which is it is the transmission linkage under the hood.
Mar 2, 2010 at 1:14 PM
SATURNTECH9
  • 30,869 POSTS
So ur talking at the transmission the bottom cable is the black ended cable if ur talking about the connection at the trans it self then it's attached by a H shaped clip a good sized one same clip that holds the top one on with.if ur talking about at the shifter tower arm it's a smaller H clip that has a tab that locks it in place just like the top cable u need to get another of which ever clip it is.let me know if u have anymore questions.the clips are probably a dealer or pick apart item though.
Mar 2, 2010 at 1:58 PM
SUSAN DOWELL
Thank you very much - that should be very helpful!!!
Mar 2, 2010 at 10:10 PM
