wher is the ects on a 1995 Saturn Sc1 with 1.9 4cyl. engine. Is it just below the upper radiator hose on the engine? Is it a 2 wire connection? This car has a seperate sensor for the temp gauge, the ects on this engine has a 1 wier conection while the temp sensor has a two wire connection. Is this opposite of what it should be? Would this cause engine to start only when gas pedal fully depressed?
Oct 4, 2010 at 10:59 AM
