1994 Saturn SC1 Recharging A/c
200,000 MILES • 4 CYL • FWD • MANUAL
JOJO2799
I WENT AHEAD CHANGED THE HOSES AND RECGARGED WITH TWO CANS OF 134 BUT COMPRESSOR DID NOT ENGAGE? COULD THE A/C SYSTEM BE AIRLOCKED OR OR A SWITCH BAD? ICHECKED THE FUSE AND IT WAS OK?
Jun 29, 2010 at 8:28 AM
  • 75,988 POSTS
Hi jojo2799, Welcome to 2carpros and TY for the donation
When you turn the AC On -do you hear the clutch engage the compressor? Your possibilities here could be low on freon, magnetic clutch, low pressure cut off switch, AC relay and AC/Heater fuse.
You can do this power the magnetic clutch from the battery and see what happens
Jun 29, 2010 at 8:48 AM
