1994 Saturn SC1
1994 SATURN SC1
MQUICK01
Engine Performance problem
1994 Saturn SC1 4 cyl Front Wheel Drive Manual
i have the 1.9 sohc. when the car runs it build pressure in the oil. when i turn it off and pull the oil dip stick or pull the oil fill cap it blows off a good amount of pressure. if the car is driven for a bit like 20 mins. it wont start till the pressure is releived
May 21, 2010 at 3:14 AM
SATURNTECH9
  • 30,869 POSTS
[quote:b5203cf6f2="mquick01"]Engine Performance problem
i have the 1.9 sohc. when the car runs it build pressure in the oil. when i turn it off and pull the oil dip stick or pull the oil fill cap it blows off a good amount of pressure. if the car is driven for a bit like 20 mins. it wont start till the pressure is releived[/quote:b5203cf6f2]
First thing i would do is check your little Z shaped hose that goes from your valve cover to you air box take it off let the car idle and see if the nipple the hose goes to on the valve cover is putting out a good amount of air.Thats your breather for the engine my guess is its plugged, or the hose, or the air box port it goes to is.Let me know what you find.
May 21, 2010 at 8:38 AM
MQUICK01
i checked the air system and its all good. i think the oil pump in bad. like a spring or something not closing all the way. that would make to much pressure in the oil system?
May 23, 2010 at 2:59 AM
SATURNTECH9
  • 30,869 POSTS
[quote:87665465c4="mquick01"]i checked the air system and its all good. i think the oil pump in bad. like a spring or something not closing all the way. that would make to much pressure in the oil system?[/quote:87665465c4]
It's not too much oil pressure your talking about blow by building up and getting trapped in the engine that's differnt then oil pressure.What your talking about is the engine gases getting trapped and not releasing thru normal means like thru your valve cover breather.If the gases are not releasing and you have to remove the oil cap to release them then there has to something wrong with the valve cover breather or where it goes too.Because that connects to the same place your oil cap does.If it was working properly it would bleed down pressure thru the breather and you wouldn't have to remove your oil cap to release the pressure.
May 23, 2010 at 7:34 AM
