2005 Saturn Relay tune up ?
MICHAEL WILLARD
Engine Performance problem
2005 Saturn Relay 6 cyl Two Wheel Drive Automatic
how do i go about replacing sparkpugs and wires on the back sie of motor
Oct 1, 2009 at 7:56 AM
BASSTECH
  • 236 POSTS
first you have to remove the throttle body air inlet duct, then set the park brake. Put the transaxle into Neutral. Then remove the engine mount struts located the front of the engine. At this point you can attach a strap to the engine and pull / tilt the engine forward to gain acces to the rear spark plugs. good luck, let me how you make out.
Feb 14, 2010 at 6:24 AM
