2005 Saturn Relay how do i change the transmission fluid pr
2005 SATURN RELAY
68,000 MILES • 6 CYL • FWD • AUTOMATIC
DEEPSEA334
do i need to change the filter also? do i need to go to a service center to get it done properly?
May 24, 2010 at 4:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
at early miles like this it would be best to have the transmission fluid and cooler lines flushed at a shop instead of simple drain and refill. the filter should be replaced as well
May 24, 2010 at 9:07 AM
