how to change thermostat
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
MDMMART
engine over heats after driving about three miles, I need to change the thermostat.
Oct 10, 2010 at 3:38 PM
BLUELIGHTNIN6
  • 16,542 POSTS
drain coolant and remove inlet and outlet hoses from housing. then remove housing bolts and housing will come off. thermostat and gasket can then be removed and replaced.
Here is a guide to show you what you are in for when doing the job with diagrams below showing how it is on your car.
Cheers
Oct 11, 2010 at 3:30 PM
