2007 Saturn Outlook Front Rotor Removal
45,000 MILES • 6 CYL • FWD • AUTOMATIC
KJZ5440
How do you remove the front rotors from a 2007 Saturn Outlook? There is a torx screw on the rotor. Do I have to remove this screw to remove the rotor? If I have to remove this screw, do you have any suggestions for removing this screw as I just broke my torx bit (I sprayed some PB Blaster on the screw).
Thanks.
Jul 29, 2010 at 11:12 AM
SATURNTECH9
  • 30,869 POSTS
Yes you have to remove the retaining screw it must be really rusted in if you can't unscrew it you will have to carefully drill it out.
Jul 29, 2010 at 12:06 PM
