1994 Saturn SC2 Wipers Quit
SATURN
DON'T CHA
I have a 1994 Saturn SC2 with 145,000 miles on it. The windshield wipers started going slower and slower til they recently quit working. I figured it was the wiper motor but just replaced it & wipers still do not work. What else could it be and how can I check it out further?
Apr 30, 2006 at 1:00 PM
PEPPERMRJ
  • 1,158 POSTS
Check the fuses and relay first. If that does not turn up anything check the motor plug for 12 volts. Keep following it back until you don't get 12 volts. check the wires and the switch.
Good hunting and let us know. :)
May 1, 2006 at 2:18 AM
Suggested Repair
Check the wiper fuses and relay first. If those are good, test the motor plug for 12 volts and trace the circuit back until voltage is lost, inspecting the wiring and wiper switch.
Conversation Summary
A 1994 Saturn SC2 owner reported windshield wipers that gradually slowed and then stopped. Replacing the wiper motor did not restore operation. The expert advised checking the fuses and relay, then testing for 12 volts at the motor plug and tracing the circuit, wiring, and switch until the loss of power is found.
