whoops i put the transmission fluid in the oil
SATURN
ROB9999
whats the worst that can happen if i put the transmission fluid where the engine oil should go?
(only 1 quart)
i have a 2004 saturn L300 it has 51,000 miles
:shock:
Mar 29, 2006 at 6:54 AM
PEPPERMRJ
  • 1,158 POSTS
In the old days that was considered a way to remove sludge. Not at all necessary with modern oils. I doubt if you will see any real problems as long as you change it ASAP.
good luck and let us know. :)
Mar 29, 2006 at 7:51 AM
