Sorry,
I think I should add a little more information to my inquiry.
The car is a Saturn SC1 year 2000.. it has about 84,000 miles.
I recently went to a mechanic when I noticed the problem and he diagnosed it as a bad engine coil. But upon further investigation with a friend of the family, I learned one of the key indications of a bad engine coil is a lack of acceleration or trouble excellerating. This is not the case with my car. Granted it has a small engine so it's not speedy to begin with... but I have not noticed any change in excelleration. I'm more than a little hesitant to pay big money to replace a part that doesn't need replacing... so I'd like to have a clear answer as to whay could be causing the problem.
If this helps... the racing idle occurs when the car is both warm and cold. If I turn off the car when it is racing... and restart.. the engine corrects itself and idles around 1,000 rpms as usual .( the fast idle is anywhere from 2 to 3 thousand rpms.) It is a manual transmission car and I have learned how to prevent the fast idle. If I slow the car to under 15 hundred rpms before depressing the clutch and coming to a stop... 9 times out of 10.. it won't idle fast.
Any ideas?
Any ideas?
Nov 13, 2006 at 2:10 AM
