2000 Saturn SL2 Vibration When Turning Right
2000 SATURN
Z_MANBG
I have a 2000 Saturn SL2. When i am driving down the road and go slightly to the right it starts to vibrate just a little. I first noticed it, it seemed to be slowing down just a little bit but i am no mechanic so i have no idea what is going on. where is the vibration coming from?
Mar 21, 2006 at 8:24 AM
PEPPERMRJ
  • 1,158 POSTS
Welcome to the forum. :)
Does the steering wheel shake?
Do you feel it in the brake pedal?
I would check or have checked the suspension and steering components. I would consider these safety issues. Ball joints and tie rod ends could cause serious damage and injury. Don't let me scare you. I don't think that a slight viration requires immediate attention. However if not addressed in a reasonable period they can be very serious.
Also check that the wheel fasteners are all tight. Wheel bearings should also be tested with the steering and suspension items.
Good luck and let us know. :?: [/url]
Mar 21, 2006 at 12:28 PM
Suggested Repair
Inspect suspension and steering components, including ball joints and tie rod ends, confirm all wheel fasteners are tight, and test the wheel bearings. A slight vibration is not an emergency, but these items should be checked soon because worn parts can become a safety issue.
Conversation Summary
The owner of a 2000 Saturn SL2 reports a slight vibration when steering slightly right while driving and thought the car might also be slowing a little. The expert asks whether the steering wheel shakes or the vibration is felt in the brake pedal, and recommends checking suspension and steering parts, ball joints, tie rod ends, wheel fastener tightness, and wheel bearings.
