transmission
SATURN
SWIZZLE
i would like to know if a engine that comes from an automatic can be used with an manual transmission the car is a 91 saturn sc with a dohc just wanted ti know if the bolt pattern is the same?
Mar 29, 2006 at 7:08 AM
PEPPERMRJ
  • 1,158 POSTS
I would think that if the years are the same then the bolt pattern is the same.
The real issue would be swapping over the computer. Saturn automatics are controlled by the PCM. You would have some unattached wiring that would probably light lights and complain in general. It has been done I'm sure.
Let me know what you are going to do and I will research further. :)
Mar 29, 2006 at 7:48 AM
SWIZZLE
[quote:13053878d2="peppermrj"]I would think that if the years are the same then the bolt pattern is the same.
Let me know what you are going to do and I will research further. :)[/quote:13053878d2]
My brother and I will be puting it in can you help with the wires from the tranny to pcm part I have alot of know how if there is a link for this help, please let me know we also have the repair manual to help out
Mar 29, 2006 at 11:44 AM
PEPPERMRJ
  • 1,158 POSTS
Check you PMs.
Good luck and let us know how it goes. :)
Mar 29, 2006 at 11:56 AM
