My problem is a loose serpentine belt. I think the spring is broken on the tensioner, or I have a loose pulley somewhere. What I can't figure out the size of the bolt on the tensioner. Is there a special wrench needed? The tensioner seems ok though i tried moving it with a screwdriver and it didn't budge. Should I get a small belt, hook it up to the crankshaft and water pump and drive it to the dealer?
thanks,
-Ben
