Slipping wiper arm connection
SATURN
REDMUNDS
We have a 1999 Saturn SW1 with 56k miles.
Windshield wiper noise has been a chronic problem. After many attempted fixes, I recently installed a set of Bosch ICON blades, which are solid rubber (no multiple metal pivots). In our first rain since, they worked great until the passenger side wiper arm began slipping. I assume that it connects to the rotating shaft in some way that allows some give if on turns on the wipers when the blades are frozen to the windshild. But I need more torque and cannot see how to tighten the assembly. When stopped, it is easy to move the passenger blade back to it's proper place, but in the heavy rain at highway speeds it would get hung up and driver blade ran into it. Ideas? Thanks, Rob
Jul 1, 2007 at 6:01 AM
REDMUNDS
In the light of day I was able to figure this one out. The metal cap over the blade base lifts up and exposes a nut over the drive shaft for the wiper which sits atop a broad rubber bearing. This was easily torqued down with a metric socket. Have not tried them in a heavy rain but it is no longer slipping.
Rob
Jul 2, 2007 at 8:11 AM
