1999 Saturn SL Stalling
SATURN
LIVINGINLARGO
I have a 1999 Saturn SL. I have replaced an oxygen sensor in bank 1 sensor 1, Vacuum hose that was leaking and replaced spark plugs and wires, but it still stalls. We have to give it gas while applying the brake to keep it running or it will stall. Any ideas where else I need to look.
Jan 14, 2007 at 9:53 AM
SERVICE WRITER
  • 9,123 POSTS
2 very common problems:
Coolant temperature sensor
(cheapest fix)-can pull it out and look at it, they often are cracked. Cheap part, just replace it.
EGR valve (can try removing and cleaning it-have another gasket ready)
Jan 14, 2007 at 12:25 PM
Suggested Repair
Inspect or replace the coolant temperature sensor, which often cracks and is an inexpensive part. Also remove and clean the EGR valve, and have a replacement gasket ready.
Conversation Summary
The owner of a 1999 Saturn SL says it still stalls after replacing the bank 1 sensor 1 oxygen sensor, a leaking vacuum hose, and the spark plugs and wires. The engine dies unless given gas while the brake is applied. The expert identifies a faulty coolant temperature sensor and a dirty EGR valve as two common causes.
