Saturn SL skipping ... sort of.
SATURN
KM4HR
2002 Saturn SL1 1.9L makes a slight puffing noise at the tail pipe when idling. It does this continuosly. So far I've:
* installed new plugs and wires
* swapped ignition coils with other cylinders
* swapped fuel injectors in #1 and #2 cylinders
* checked computer codes
* checked compression (150 psi all cylinders)
Check engine light is on. Computer codes were checked at Advance Auto Parts. The printout said "skipping on #1 cylinder".
Skipping is not noticable on the highway. Why is it sputtering at idle? How do I stop it?
May 11, 2007 at 3:48 PM
SERVICE WRITER
  • 9,123 POSTS
Check for a vaccuum leak. Pick up at the bottom of this thread on page 1:
https://www.2carpros.com/forum/1-vt29176.html?postdays=0&postorder=asc&start=0
You may want to do the chemical cleaning in that thread also.
May 11, 2007 at 4:02 PM
