2001 Saturn SC2 Won't Turn Over
2001 SATURN
FRANK TEICHE
I have a Saturn SC2 that wont turn over. The battery checks fine and when you turn onthe lights they are bright and do not dim when the key is turned. there is a relay click when you turn the key. I have not found a wireing diagram to check the voltage to the starter yet. What else could cause it not to turn over?
2001 SC2
milage 78000
automatic
1.8 dual overhead cam
Jun 17, 2007 at 12:04 PM
SERVICE WRITER
  • 9,123 POSTS
Nice try Frank!!! That's 1.9!!!
https://images.2carpros.com/forum/automotive_pictures/30961_wtfcat_qjpreviewth_1.jpg
Okay, but seriously...... The battery is fine, that leaves the connections at a possiblility or the starter. So carefully check the conections for looseness or corrosion (unlikely), or get a starter that is dependable. Glad to give my input to what I have had luck with or any info you need.
Jun 17, 2007 at 2:00 PM
Suggested Repair
Check the battery cable connections for looseness or corrosion. If the connections are sound, test or replace the starter.
Conversation Summary
The owner of a 2001 Saturn SC2 with an automatic transmission reports that the engine will not turn over. The battery tests fine, the lights stay bright when the key is turned, and a relay clicks. The expert notes the engine is a 1.9 and recommends checking the battery connections for looseness or corrosion, or replacing the starter with a dependable unit.
