saturn 2003 Vue
2003 SATURN
KSVW
I can't get the headlight pod out to change the low beam headlight. The release mechanism doesn't release.
The owner's manual photo is poor!
Any suggestions??
Thanks!
Jul 15, 2007 at 10:12 AM
KSVW
Hi Car Pros ~
I removed the side pod and the 2 bolts to the upper bracket to the headlight pod but can't get the lower bracket release mechanism to release the lower bracket!
So I can't get the headlight pod out to change the low beam headlight bulb. The release mechanism doesn't release the lower bracket.
The owner's manual photo is poor! The photo appears to be different from what I can see.
Any suggestions??
Thanks!
PS ~ Are there how to's for other maintenance work? I looked but didn't find any ~
Also, I'd like to buy the special oil filter tool the Saturn Vue, V6 requires to change the oil filter. Do you sell that tool?
Thank you for all you do!
Jul 16, 2007 at 2:36 PM
