saturn 1994 automatiac transmission
1994 SATURN
HOTROD1935
  • 5 POSTS
when i bought this saturn the trans would work ok til about one mile down the road. then it would like it had no gear only first gear i chang the trans . Same thing . pull it out and replace it Same thing again> odb1 reader has a no code til i drove it about one mile and the trans started doing the same thing . i got out the obd1 code reader and it came up with code 22,23,24 .. when it shift in to high gear it will work ok if i don,t try to go fast then if i do it like putting it out of gear take my foot off gas pedal and it go back in high gear NOW WHAT SHOULD I DO did i get two bad trans ?? (ps) getting good at changing trans
Jan 13, 2007 at 3:56 PM
SERVICE WRITER
  • 9,123 POSTS
22-Throttle position sensor-voltage low
23 -IAT circuit low
24 -VSS circuit-no signal
83- Donation-no signal
Jan 14, 2007 at 12:08 AM
HOTROD1935
  • 5 POSTS
what is the code 23 -IAT circuit low ?
code 24 -VSS circuit-no signal ?
Jan 14, 2007 at 12:14 AM
CLEAVAGE4U
  • 69 POSTS
MR Hotrod,
Are you bein coy? :roll:
I like your username a real lot :wink:
I betchu got another real fast car, cause of that "1935".
Jan 14, 2007 at 1:13 AM
HOTROD1935
  • 5 POSTS
[quote:362c202970="Cleavage4U"]MR Hotrod,
I betchu got another real fast car, cause of that "1935".[/quote:362c202970]\
not being coy
Yes i have a 1935 ford streetrod 2 door sedan humpback with all the goodie insid and out it has a bbc,700r trans with corvette Suspension front and rear only thing i had done was the chrome and upholstering
Jan 14, 2007 at 3:06 AM
SERVICE WRITER
  • 9,123 POSTS
Cleavage, are you out flirtin again? :) Looks like you sniffed out another speed demon 8)
Post a pic of your car if you want.
There is a tsb about updating the pcm software whan the tranny is changed or having the wrong tranny, it specified the codes you have.
Jan 14, 2007 at 4:22 AM
HOTROD1935
  • 5 POSTS
how do you update the pcm software ?? the trans came out of a 1994 saturn with dohc and that what my saturn has .
Jan 14, 2007 at 5:04 AM
