Replacing 2002 L100 water pump
2002 SATURN
BEEDEES
I have a 2002 Saturn L100, 2.2L with 110680 miles on it. Today the water pump started leaking, I am needing either a diagram or an explanation of how to replace it. If you could help, it would be greatly appreciated.
Sep 14, 2007 at 11:21 AM
DONNYS
[quote:3b1ae52e48="beedees"]I have a 2002 Saturn L100, 2.2L with 110680 miles on it. Today the water pump started leaking, I am needing either a diagram or an explanation of how to replace it. If you could help, it would be greatly appreciated.[/quote:3b1ae52e48]
I dont have an answer for you, and I'm probably in the wrong forum, but...I have a 1998 saturn (4door, 4cyl, dont know model#) with about 80k miles on it. I noticed a huge puddle under my car today. So, i got under it and think my water pump is leaking. When I put more coolant in, I could see a steady drip with the car off! I simply want to print out a "PDF" (from manual) file of some sort, showing a diagram on how to replace it myself. Is that possible? How?
Sep 25, 2007 at 2:04 AM
