Problems with 93 saturn sw1
1993 SATURN
GUITARDUDE012
Hi- I have a 93 saturn sw1 with approx 110k miles on it.
My main problem is that I am getting erratic fuel level readings at the dash. It appears that the level with either be correct or read low, but never read high. It also seems that the level will drop low for a while but then go back up under harder acceleration.
Another issue is that a while back (atleast 6 mo's) my odometer would work off and on, but has now stopped completely. It stopped well before I started experiencing the fuel level indicator problems. I read on the forums that people had problems with red gears?
It seems that I am getting very poor gas mileage lately but it is hard to tell with no odometer and an erratic fuel level display.
Thanks
Apr 29, 2007 at 3:54 PM
PEPPERMRJ
  • 1,158 POSTS
Hey Guitardude,
There is a possible easy fix for the fuel gauge reading. I will send you the procedure.
Does your trip meter work?
Here is a link to the red gear deal. I can send you further info f you still have questions.
https://www.2carpros.com/forum/odometer-quit-after-clutch-replacement-vt5199.html?highlight=red+gears
Good luck and let us know. :)
peppermrj
May 5, 2007 at 11:21 AM
GUITARDUDE012
Thanks I would really appreciate instructions on fixing the gas problem. I have noticed since I posted that it seems to only have the problems below what it reads as 1/2 full tank.
I specify "what it reads as 1/2" because it is a 12 gallon tank I believe and it reads empty at 4 gallons ;)
The trip odometer also does not work.
Thanks again
May 6, 2007 at 2:50 AM
