Poor acceleration
SATURN
JPK1291
  • 7 POSTS
I have a 97 SL1 1.9L SOHC 115,000 miles, that I just replaced the head due to a crack. Head is reman from saturn. New head and manifold gaskets installed. I now have terrible acceleration. Car WILL NOT go over 3800 RPM. The transmission shifting is also terrible. Upon accel if I don't let off the gas, it will not shift to higher gear. All hoses , wires appear to be connected and unbroken. I had the battery disconnected for 2 wks before fixing the car. Is there any relearning curve for computer to get back to correct shifting patterns?
Confused in Niagara Falls!!!
Oct 29, 2007 at 1:10 AM
SERVICE WRITER
  • 9,123 POSTS
Niagara falls huh, I'm in your backyard.
I'll get back with you.
Any codes?
Oct 29, 2007 at 1:24 AM
JPK1291
  • 7 POSTS
When I first started it, it ran rough and returned a p300 code. Now runs smoothly until it reaches 3700rpm.
Oct 29, 2007 at 1:47 AM
SERVICE WRITER
  • 9,123 POSTS
Haven't had a chance to get back. One thing I would definitly take a look at is the coolant temp sensor for any cracks and spray a little carb cleaner around the intake and injectors to be sure of no vaccuum leaks.
What was the reason for the head replacement. Overheat?
Oct 29, 2007 at 4:56 AM
JPK1291
  • 7 POSTS
Head was cracked. Oil in coolant system. Will try what you suggest when I get a chance, wife in hospital right now.
Oct 29, 2007 at 6:32 AM
JPK1291
  • 7 POSTS
Thanks for all the suggestions. I took the timing cover back off and saw that I had put the chain/gear back on 1 or 2 teeth off. Corrected this, put it back together, and it runs great now. Again thanks for your replies. I was wondering if the cam alignment might be the cause, and multi responses suggesting this prodded me to recheck. THANKS
Nov 7, 2007 at 11:10 AM
SERVICE WRITER
  • 9,123 POSTS
Thanks for the update, Funny, about diagnosing, you want to assume what you did was right.
Hope all is well with the wife.
Nov 7, 2007 at 9:10 PM
JPK1291
  • 7 POSTS
She's out of the hospital. Off/on feeling good and then bad. Multiple medications will hopefully eventually get rid of pain. Thanks for asking!!
Nov 11, 2007 at 7:23 AM
SERVICE WRITER
  • 9,123 POSTS
Small world...There is so much sickness in NF...how can it be so screwed up? While this is a car forum...my heart sinks knowing customers and the health issues of our area. So sorry to hear about the pain.....that is really upsetting.
On a good note, the Satty runs good huh?....Take care of the Honey...and stop back in here anytime.
Nov 11, 2007 at 9:15 AM
