P0411 Secondary Air Injection Malfunction
SATURN
ILUVMUD
I have a code P0411 Secondary Air Injection Malfunction on my 2000 Saturn SL2 . I replaced the EGR and it went away for a couple of days, but it's back. Any thots on fixing it for good?
Mar 22, 2006 at 12:02 PM
PEPPERMRJ
  • 1,158 POSTS
The code relates to the air pump itself that is located on the passenger front of the engine. It is a round black thing that has vacuum lines and electrical lines coming off of it. It also has a small diameter metal tube running from it to the center of the exhaust manifold.
I would start by tracing the vacuum lines and the electrical lines. Make sure all are intact and connected properly. I'm thinking you have a loose vacuum line.
Good hunting and let us know what you find. :)
Mar 23, 2006 at 1:20 AM
